Old 04-26-2016, 08:11 AM   #2
Gilles
Particlewave,
I received the pictures of the location of the Power Distributor, and now I know that before you can lower it into the passenger floor, first you need to remove the nuts next to the battery...
Hopefully there is a blown fuse, it mentions F-5 for the engine electronics with a rating of 80 Amps ..!
When I removed the starter to get it checked, I ensure that the connectors with the 12VDC were tight, and also checked the ground connectors between the engine and the frame
I will inspect the power distributor box tonight and let you guys know, I do really appreciate all the kind support and suggestions!
Regards, Gilles
