Old 04-26-2016, 04:53 AM   #4
AmongstEnemies
Hey guys thanks for the responses
Originally Posted by ppbon View Post
Are you sure the radio is wired correctly?
There are at least two wires that are hot when switched.
One is dependent on the ignition switch alone but the other one is connected through a time delay.
When you disconnect the car's battery the relay resets.
Most likely your radio is not connected correctly.
Happy Boxstering
Pedro
I have no idea if the radio is wired correctly, who put it in or when it was put in. Do you know where I can get it properly connected/wired?
Was the OEM radio a Porsche CDR24?
Then you'll need a CAN bus adapter to get correct CAN bus plus from ignition.
Do you have a Bose system in your car?
If you have a Bose system you'll need an MOST bus adapter additionally.
Regards, Markus
Unfortunately I don't know if the OEM radio was a porsche CDR24. what does CAN stand for?
Yes my car has a Bose system. what are these CAN and MOST bus plug/adapter?
98 Integra (learned on)
2015 Brz (totaled)
2005 Boxster (Current DD)
AmongstEnemies is offline   Reply With Quote
