Are you sure the radio is wired correctly?
There are at least two wires that are hot when switched.
One is dependent on the ignition switch alone but the other one is connected through a time delay.
When you disconnect the car's battery the relay resets.
Most likely your radio is not connected correctly.
Happy Boxstering
Pedro
Racecar spelled backwards is: Racecar!
