track prep
At the minimum, you will need to change your brake fluid. Check your tires (tread depth, pressures, and age) as well as brake pads (thickness) - a day at the track can go through brake pads in a hurry.
Most likely the group that you go to the track with will have a tech sheet with a full checklist of items to inspect and check. Then come track day, you will have tech inspection where your car is gone over (all be it quickly but checked none the less)
Enjoy the track day - it really shows what these cars can do!
