Old 04-24-2016, 07:47 PM   #27
Duezzer
Make sure you don't over torque the nuts - Only 7 lbs I believe and use the metal gasket!
Take a piece of cardboard and make a drawing of the pump housing and where the bolts go -- they are different sizes - I pushed them thru the cardboard drawing. This kept me form screwing them up. You will need a knuckle socket to get to one of the bolts.
there is a bleed under the oil/anti freeze surround - You will need to vent as you top up the coolant or it will not go in.
Happy Wrenching.
Duezzer is offline   Reply With Quote
