I usually have at least one in stock but I've been hit hard on those lately. I also ran into a batch of bad ones. FYI, they're not side specific but you should double check the low and high speed work before you go through the hassle of installing one. It's very easy to do with a battery charger or even jumper cables. I think the black wire is the ground and the white and green are for the slow and fast fan. Slow is usually the one that goes out first and the problem 90% of the time is a burnt out resistor. There's a thread out there where someone replaced just the resistor.
Woody
