Old 04-24-2016, 06:26 AM   #12
cornontherob
cornontherob's Avatar
If you can get the camshaft deviation values, get them. Likely from Durametric or a porsche tool. Camshaft adjusters lie in between the camshafts.
Getting that out means removing the valve cover, locking down the timing with a special $184 tool, locking the crank, removing camshaft bearing caps, removing the sprocket from the camshafts, then removing them both. You'll then replace the adjuster, which will cost around $1,500, and after that you reset the timing in respect to the two camshafts, put them back in the car, set the timing in respect to the crank, and drive.
cornontherob is offline   Reply With Quote
