Old 04-23-2016, 08:26 PM   #11
GTsilber
I guess you've got to do a little more digging with the top.
First off, handbrake illumination does not mean the microswitch for the top is good, Bypass the switch at the top controller relay. See Pedros DYI for instructions, its easy and once you do it, you'll like it!
1, Beg, borrow steal a new top controller relay and see what happens.
2. Get out the top pry bar and disconnect the pivot arm ball joints to allow top and clam shell to operate manually. This will allow you to inspect the mechanical aspects of the top operation, along with allowing you to place the top in any position you want.
3. with top disconnected, get to the tops motor, which is directly underneath the rear window. Disconnect drive cables (to keep both sides in sync) and power the motor directly to check its condition.
Thanks for the help...wasn't sure which Pedro article you were referring to but I tried the one for bending back pin 18 to drop the top while moving...didn't work for me [emoji853] is there another article that I should try?
How do I get my hands on another relay to test?
GTsilber is offline   Reply With Quote
