Old 04-23-2016, 08:37 PM   #11
dghii
Originally Posted by GTsilber View Post
I have been trying to trouble shoot my top issue, so far no luck. Here are some things I tried and observations:
1. Check handbrake is illuminated in dash when pulled - confirmed
2. Check top microswitch is working correctly - when pulled Windows go down, when pushed up windows roll up - confirmed
3. Remove top double relay and reinsert - confirmed but not sure if relay is bad?
4. Replace B6 fuse - confirmed
5. The top warning light does not illuminate when placing key in ignition, not sure if it should
6. The top rocker switch does not illuminate with yellow light, upon toggling switch no sound from top motor or otherwise
What else can I try?
On another note, got a CEL light, P0420. Hooked up my OBD2 and noticed that B1S1 and B1S2 are showing similar voltage, do I need to replace S1 or is it the cat that's bad?
The windows toggle up and down with the microswitch in the top latch assembly.
I guess you've got to do a little more digging with the top.
First off, handbrake illumination does not mean the microswitch for the top is good, Bypass the switch at the top controller relay. See Pedros DYI for instructions, its easy and once you do it, you'll like it!
1, Beg, borrow steal a new top controller relay and see what happens.
2. Get out the top pry bar and disconnect the pivot arm ball joints to allow top and clam shell to operate manually. This will allow you to inspect the mechanical aspects of the top operation, along with allowing you to place the top in any position you want.
3. with top disconnected, get to the tops motor, which is directly underneath the rear window. Disconnect drive cables (to keep both sides in sync) and power the motor directly to check its condition.
