Old 04-23-2016, 12:37 PM   #1
stepwilk
side airbag removal w/o turning on reset light?
I need to remove the driver's-side interior door panel to effect a window-switch repair. If I disconnect the battery before doing this, will that prevent the airbag-inop light from going on after I disconnect the airbag wiring (which is a necessary step in removing the door panel)?
Obviously I can take the car to the local Porsche shop to have the warning light reset after I reinstall the airbag and door panel, but it will be easier if I don't have to do this.
stepwilk is offline   Reply With Quote
