Old 04-22-2016, 12:55 PM   #1
Racecar_Dave
Myriad of electrical problems
So earlier the boxster was failing to start, i replaced the ignition switch then immediately the immobilizer started having problems. it would cycle locking and unlocking the doors even with the key out. i opened it up, found corrosion, took it to my local motherboard shop, they cleaned it up using iso and another chemical (which i forgot) and gave it back shiny new.
It solved the door cycling issue and the car starts right up no problems but now i have no control over the windows. if i put the top down the car will roll the windows down a third of the way and it will roll the windows back up after i close the top but i have no function at the window switch. now to be honest i was having an intermittent window problem before fixing the immobilizer board
and the spoiler is stuck in up position
the airbag light is on (when i scanned the car earlier this month i did receive a code for passenger door airbag but it wasnt triggering the airbag light then)
the central locking is no longer working
any ideas?
1999 BMW M3
1985 BMW 350i (SBC swap)
1984 Buick Grand National
1971 Volkswagen Superbeetle
Racecar_Dave is offline   Reply With Quote
