Old 04-21-2016, 03:29 PM   #11
muscatty
Originally Posted by tada View Post
Just read an article on cam timing. Can this be done without dropping the engine?
I can tell you from past experience that it is possible to check the cam timing without dropping the engine. Checking the timing only requires being able to rotate the engine to TDC and removing the 6 green plugs. I used the camera on my phone to take pictures of the cam notches so it was easier to see.
This post had some good information that might be useful:
DIY: Setting Cam Timing on M96
muscatty is offline   Reply With Quote
