Originally Posted by Ben006
Depends on the quality of water where you live.
Tap water can cause scale and electrolysis.
Distillied water is 64cts a gallon, it's worth it
This is 100% correct. Two gallons is just under half the entire coolant system, so I would drain the system, flush with a lot of distilled water and replace the coolant with the correct 50/50 mix.
