If you grind the finger of the ball joint separator tool where it hits the end of the ball joint, you might be able to make it less likely to slip off. On mine (not the same brand), I ground it flat - maybe a bit concave, and it stays put now. Also, the ground area isn't as slippery as the factory finish.
