Old 04-20-2016, 09:57 AM   #11
Smallblock454
Hi Tom,
thanks for the feedback. Because the engine was cold i the values are OK – engine should run with this values on all 6 cylinders.
Could you please check these things:
  • Is the exhaust system on the left free floating. Means maybe you have a clogged / blocked catalysator and the exhaust gas can't escape.
  • Same for the intake. Please check if everything is free and nothing is in there - no air, no explosion.
  • Check if all sparks ignite.
  • If you have a tool to check if you have ignition on sparks when motor is running, please check that. In german it's called ignition lamp - don't know wthe correct english term is. It visualizes spark ignition.
Hope that helps or maybe get's you another idea what you still can test.
Regards and fingers crossed
Markus
PS: it's always a bit tricky for me to describe these things in english, because i don't always know the correct technical terms. If something is misleading, please ask.
