Old 04-19-2016, 10:34 PM   #1
Gilles
lost all power… Help please..?
First I would like to mention, that I am completely electrically impaired (seriously).
Yesterday after leaving a shopping center, the car died and lost all electrical power, the instrument panel was completely dead and could not remove the key.
I finally was able to open the trunk after powering the lighter with a battery charger, and left it charging for almost 24 hours, and tonight when I got back from work, the charger was showing full charge and when I tried to start the engine everything went dark again.
Assuming that I had a bad battery, I remove it and went to the auto parts store where they determined the battery to be in good condition, went to a different auto parts and same results.
After reinstalling the battery, all the accessories came back to life (radio, windows, courtesy lights, etc.,) but as soon as I turn on the key, you can hear a click noise on the starter and all the electrics go dead again and using jumper cables does not help either.
However, if I disconnect one of the terminals on the battery for a moment, then everything starts to work again, until you try to start the engine, then you hear a solid clack from the engine and everything goes dark again.. I repeated the cycle of disconnecting the battery a few times but ended with the same results.
What could be wrong? The fuses seems to be ok..
I am in concerned (bad timing) because I borrowed my neighbors garage for one night because I was not comfortable leaving the car outside with the windows open
Help Please..?
Gilles is offline   Reply With Quote
