I work on my own porsche. Haven't paid a pro for any labour yet, although there is a good local shop that would get the work if I needed to fork out the $$$ for something I couldn't do.
My list over the past 7 yrs.
Oil and filters
Air filter
Replaced hvac display with a part of eBay
Aux input on the stock radio for ipod
Cv joint repack, and reboot
Spark plug tubes
Pedro mount, soon going back to oem
Lightbulbs
Brake flushes
MAF, tested low voltage with multimeter, Replaced.
Passenger window door switch. Fixed loose connection that wasn't dropping the window properly when opening /closing that door.
Buffed the car with a PC random orbital buffer.
Dropped and inspected oilpan last yr, resealed with no leaks.
New head unit and small slim 10" crutchfield sub.
Removed and disassembled starter and lubed a sticky bendix(?) gear.
AOS.
windshield wipers
I top up my own windshield washer fluid.
I got a maxjax lift in my garage a few yrs ago, and it makes life much easier, although I did the 1st Cv joint and the motor mount with Jack stands.
Lots of good resources on the Web and in print form. Forums are a big help.
Still not great at reading the wiring schematics in the Bentley manual.
Dropping the tranny this spring should be interesting.
Sent from my SM-T700 using Tapatalk
