Old 04-19-2016, 10:31 AM   #11
lkchris
lkchris's Avatar
Originally Posted by rfuerst911sc View Post
Will these cigarette lighter input maintainers hold/keep the radio codes and stop any ECU issues when changing the battery ? Can you keep these plugged in while you change the battery ? I assume if the answer is yes you should be careful with the positive battery cable in regards to hitting chassis metal while doing a battery switch ?
Your Porsche interrupts power to the cigarette lighter when ignition is off ... hence these are of no use.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
