Old 04-19-2016, 09:26 AM   #4
cas951
I used a Phillips screwdriver and touched the point to the center of the cigarette lighter and connected the negative of my charger to the door jamb....worked like a charm....the pull out thingee in the fuse box would not do anything
You are brave and must have steady hands to be able to do this. I wouldn't recommend this procedure to anyone unless it's an emergency and no other option available.
For me this product can do double duty. Keeps my devices charged when on the go and maybe power up the car just to open the trunks when the need comes. As far as using it to jump start I don't think 10 minutes plugged in is enough time to jump start the car. It's also safe to use for the clumsy ones.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
