Originally Posted by Paul
I recommend you disconnect the battery and repair the wiring before running the car again. The blue and white wires are twisted pair so they are most likely part of the car's Canbus network. Cheap way to fix: splice them back together and seal them up with some heat shrink tubing. Tape up the yellow wire with heat resistant electrical tape.
Expensive way to fix: replace harness.
+1 really good advice. Allowing them to short may become very frustrating and expensive.
