Old 06-13-2006, 09:10 PM   #3
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by MNBoxster
Hi,
You do not need to remove the panels. But, if you did, you'd only need a philips screwdriver and a little dexterity. It's a pretty easy procedure.
If changing plugs, consider replacing the Spark Plug tube seals while you're at it. They're cheap and have been redesigned since your Car was built.
Personally, I'd have them on hand because you won't necessarily know if the existing ones are leaky until you get in there. If you already have them on hand, it's a piece of cake. If not, you either have to wait to complete the job, or start all over again when the parts arrive.
If it turns out you don't need them, save them for the next time...
Happy Motoring!... Jim'99
Do you happen to know the part no. for the spark plug tube seals? Would these also be referred to as "o-rings"?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
