If you are going to do a coolant tank and a complete system flush, it would be a good idea to replace the water pump and thermostat at the same time, especially if they are original.
Also, you should get a new sensor and the upgraded cap for the coolant tank.
If you don't have the knowledge and tools to do all this work, your best bet is to let the dealer do the whole job. Probably around $1500 for everything.
'99 black 986
