Originally Posted by steved0x
It would be roughly the same as the SIR tool with one major difference - the SIR tool can pull the hub, the Arnnworx tool cannot pull the hub, you would have to find a way to do that, such as a slide hammer or using bolts threaded through the hub to press on the wheel carrier and push the hub back out.
So I guess the big question is, is the sir tool worth the extra cost for that feature?
