Old 04-14-2016, 02:54 PM   #22
Gilles
I'm not him, but if you choose the EPC valve the operation of it is like this:
Thanks Steve,
I believe that my question was mostly related to your No. 6
"When you get done driving, rev up the engine to around 3000 or so for a moment (if you have an oil pressure gauge, rev up to your desired pressure and hold for a moment) and then turn off the switch that enable the electronic valve, and then shut the car off, thus storing pressurized oil for the next start"
If you forget to shut off the electronic valve switch, when you turn off the engine (closing the valve through the switch) the Accusump should be already charged, this way as long as you remember to flip the switch when you turn on the ingnition (but before engaging the starter), you would be avoiding a dry start.
Is mi assumption correct?
