You need to remove the battery and install a good known replacement. Connecting a good battery in parallel with your existing (questionable) battery doesn't always work as a poor performing battery can compromise the donor.
With your multimeter, check the battery voltage across the terminals - you should see at least 12.5v without the engine running. To check the alternator output, with engine running you should see at least 13.5v at the battery terminals.
2001 MV Agusta F4.
