Old 04-14-2016, 02:04 PM   #11
Gilles
Originally Posted by tada View Post
But I can never get the leverage necessary to completely get that locking ring over the fitting. The only way I can see to get the necessary leverage is to remove the air box, which looks worse to remove than the AOS.
I don't know if dielectric grease or even oil would help this hose attach to the valve.
Tada,
I would recommend to lube the o-rings on the accordion tube as these are easy to damage when you are pushing trying to secure the locking ring.
Also, examine closely the accordion hose as a crack can be difficult to see, yet will have a vacuum leak and make a mess if left unattended.
Good luck.
