Old 04-13-2016, 11:55 AM   #2
rastta
rastta's Avatar
I have the kit and have done the rear and am about to do the front.
Pelican shows it wrong on their website in Figure 16, when pulling the hub there is no backing plate used, just the big 27mm nut that is used to counterhold the back when you are turning the 24mm nut on the front side. I made that same mistake and twisted the end off my 3/8" breaker bar. Luckily the tool is much stronger than a harbor freight bar...
Ok - I guess I should just order the Pelican kit - if it can do both size bearings. It's much cheaper than the master kit - which has a bunch of different size plates.
rastta is offline   Reply With Quote
