Old 04-12-2016, 09:07 AM   #4
JFP in PA
Originally Posted by DWBOX2000 View Post
So from my manual, the four points are just the 2 on both sides that the provided jack attaches to. So next question. how does one jack up using those points and them put the car on jack stands if the designated spot for the jack stand is already being used by the jack. This would seem like you can only work on these if you have a lift. My two sources were pelican and Bentley. That is really bad if they are wrong since they are the main source of info for most of is.
Simple: You insert a jacking pad, and jack the car up:
