Old 04-11-2016, 06:25 PM   #1
DWBOX2000
Rear jacking point
A bit confused now. My mechanic told me not to Use the area suggested by one source which is the corners of the rear large bolt on aluminum chassis reinforcement plate which I think puts pressure on the rear suspension arm mount or diagonal brace. Bentley manual says to use the rear axle support point in the middle of the car. I been using the first method. Are they both right?
Thanks,
David
DWBOX2000 is offline   Reply With Quote
