Originally Posted by Black Jack
BMW part number: 616 742 908 68
You'll get 2 nozzles for $37
You can 'click' them out (I used a plier with a cloth to pull them out) and then you push them back into your washer (they 'click' in).
Probably the holder of your washer head (in which you'll click the nozzle) cracked and when you'll use your washer again this new nozzle will be gone again...
It's pvc so I used some pvc glue to glue them in place (just a bit of glue on 'the ball' then push the nozzle in and direct it downwards (because you cannot adjust the washer anymore after the glue has set)...
Thanks! I appreciate that.
Bart
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
