Old 04-09-2016, 06:40 AM   #12
boxster
Latest part number I have is 996-107-025-59 (retails for around $280) for the cooler. And never reuse the four O-rings, you will end up with leaks. We also have never used aftermarket versions of this cooler, only the OEM.
The 99610702557/1 part number is a discontinued item.
Ok thanks, ill try and buy an OEM version then, together with new o rings
boxster is offline   Reply With Quote
