Old 04-09-2016, 04:59 AM   #10
JFP in PA
Originally Posted by boxster View Post
Do you know the part number for the oil cooler? I found a behr/ hella model number 8MO376726-111 and it says its for Porsche part number 99610702557/1. Is this the right one please? Will it have same o rings as on the base model? Can I use my o rings with it or would they have to be new? Reason I'm asking is that the shop that has the oil cooler doesn't stock the o rings.
Latest part number I have is 996-107-025-59 (retails for around $280) for the cooler. And never reuse the four O-rings, you will end up with leaks. We also have never used aftermarket versions of this cooler, only the OEM.
The 99610702557/1 part number is a discontinued item.
