Old 04-08-2016, 09:37 AM   #10
boxster
Only the very earliest 2.5L cars (1997 and early 1998) had an odd ball setup that used and adaptor plate between the oil cooler and the engine, and these also lack the small upper return line running from the top of the cooler to your surge tank in the trunk. Yours should not be that way, but you can easily check on it by looking at the existing cooler.
And are the o rings a PITA to get hold of?
boxster is offline   Reply With Quote
