Old 04-08-2016, 08:37 AM   #10
boxster
So along those lines.
I replaced WP, low temp thermo, Flushed coolant and replace with Pink.
Last weekend I finally got to drive for several hours.
Using the Torque app:
I was seeing temps 10- 20 degrees cooler (Outside temps were in low 40's)
On the Hwy (1/2 hour at 75-80 mph) I use to see rock steady 193 degrees
I was now seeing rock solid 174 degrees
The gauge was always above the 180 mark, now it was running a bit under the 180 mark
Driving stop and go, low speeds, lots of shifting, higher RPMs - mid 180s
At stops, it would creep into low 190s. As soon as I started again back to mid 180s
It will be interesting to see how the temps behave when it 90s outside
And you still have original oil cooler?
boxster is offline   Reply With Quote
