Old 04-08-2016, 06:26 AM   #1
JFP in PA
Ignore your mechanic and install the S oil cooler. Even without the low temp stat, the S oil cooler has nearly twice the surface area for shedding heat to the coolant, which will lower your oils normal operating temps, improving the oil's life expectancy. Adding the low temp stat makes it that much better. These are two of the best low cost mods you can do for the car.
