A rib in the housing this spring was rubbing against was also noticeably worn (worn spot visible in attached picture). I decided to lightly lubricate the whole outside and inside surfaces and ends of the spring, some accessible areas of the inside spring as well, as well as the whole length of the ribs inside the housing, before reassembling.
2001 Boxster
