Next, there are three tabs you can lever away from the housing's inside surface with a very small, flat screwdriver. Then, push upward on the shaft to press out the spring and potentiometer assembly from the housing. (Be sure to keep track of the orientation of things so you can reassemble in the proper orientation - recommend using a sharpie to mark index of things, or take photos as you go.)
2001 Boxster
