Old 04-06-2016, 03:48 PM   #10
mikefocke
Is there a difference between the steel bearings used by Porsche and in the Pelican sold kits and ceramic bearings. Yes. Cost for one. But the design specs of the ceramic bearings from LN are way way beyond those of the steel ones. And the car owners experiences seem to bear this out.
Are all the Porsche used bearings the same? No. There were three Porsche-installed versions: Double row - good. Single row - worst. Large single row but not easily/cheaply replaceable - better.
LN initially suggested a shorter interval before replacement when they offered their first kits.
Why did they do that? Because initially they weren't able to install enough of their kits and get enough years and miles on them to give them a statistically valid measurement of how long they would last. As installations ran into the thousands and years and miles mounted, they gradually increased the recommended interval. The interval varies with which LN choice your engine accepts and the choice you make. Oh, by the way, LN/Flat6 have produced up to 4 different kit designs that might fit your engine. Some are expected to outlast the car and engine. Some are better than others. Costs are different.
Have there been failures of engines with LN bearings installed? Yes. Some were obvious amateur installations. Force them in sideways and see what happens with any bearing. Don't freeze them, almost sure to fail. Some were put in contaminated engines though the owner would never admit that. Some were even done days before selling the car by shysters. And they were a very few early in the production that showed problems when taken out in the shorter interval then suggested. LN asked for those back. Made good on their guarantee. Even changed one of their designs shortly after production started because of some very few early failures. Haven't seen that type of failure since. And some were installed in engines where the mounting holes for the IMS and the crankshaft weren't aligned with each other correctly from the factory or as the result of a prior failure.
I follow the IMS issue on 7 forums. Have for 7 years or so. Even so I guarantee I don't know it all. I can't recall a failure reported recently in an engine where the pre-installation qualification was done.
Lots of botched installations done by people who had not ever done something like this before.
If you stick with the LN recommended installer, insist on the pre-installation qualification inspections, and have a clean engine with a block where the mounting holes run true to each other, you should be fine. Some online instructions will lead you to big trouble just as they have others. Your approved mechanic will use LN's instructions and tools and may well have been to a class they teach with hands on experience taught by the guys who created to whole IMS replacement kit idea in the US.
Can you do it yourself? Some can. Some obviously couldn't.
LN has sold well over 10k of their kits.
Unfortunately, lots of loyalty driven posts have been seen in the forums on the IMS subject. Some advocacy based on personalities. Some defensiveness of a products reputation based on knowing things from talking to the installer.
Could some of the other bearing designs be better long term? Maybe but none has the years and miles of user experience supporting their claims like the LN products. And many ads seem IMHO to be marketing hype with claims that don't seem to be backed up by any evidence that I've seen of many successful installs with many years and miles.
How much to do/spend on preventative maintenance is up to you.
Ultimately, it is your car, your money, your choice. Good luck.
