03 Boxster S...what is this sound ???
Take a listen to this video and let me know if you've had this problem or what you think it may be. Thanks : )
https://youtu.be/c8v8lsIujVc
So here is what happened: - I heard this noise with no other symptoms, I thought, coming from the tank, no brainer, its the pump. Replaced the pump...easy. Did not solve the problem.
- Still no other symptoms other than the noise Then I did some more research and found the comments about the Fuel Tank Vent Valve on Filler Neck, (aka Bleeder Valve), I changed that. Did not fix the noise, AND I was able to fill the tank once but last time I tried to fill the tank it wont accept the fuel.
- So now Im looking for help. Any help is appreciated.
Thanks. : )
Pete
2003 Boxster S
1968 Camaro
http://www.cardomain.com/ride/2543196/2003-porsche-boxster
