The way I looked at it was this... If I have to replace it every 75k, it's not a permanent solution, so I'm going to install an OEM bearing and at least be able to determine if the bearing is on its way out via debris in the filter, and my physically checking the bearing at an interval in-between.
From what I can tell, you can't detect a failing ceramic bearing in the same way because it is obviously not magnetic, and perhaps much worse for the engine and running surfaces if the balls start to deteriorate to a much finer ceramic particle, if not all out fracture immediately and take out the engine in a few revolutions.
