Old 04-05-2016, 12:19 PM   #2
JFP in PA
Originally Posted by DWBOX2000 View Post
I appreciate any feedback. Just trying to get some educated opinions versus the ads I read.
The current LN recommended replacement is 6 years or 75K miles. That said, many of the installed single and dual row LN bearings have exceeded 75K miles with no apparent problems. To date, I have not heard of a correctly installed LN bearing failing at any mileage level from age or wear.
If you are that concerned about possibly having to replace it, install the IMS Solution instead. With no moving parts and a pressurized oil feed, it will outlive your engine and is considered the only permanent retrofit.
