Old 04-05-2016, 10:30 AM   #1221
particlewave
Originally Posted by Edreamsz View Post
Aren't the ones supplied canbus friendly?
Yes. This is difficult to diagnose from afar.
Generally, I'd suspect the obvious culprits first. The HIDs do draw a higher burst of current on fire up, then settle down. This burst could cause weird behavior if your battery were not ideal or if your headlight or ignition switch are failing.
Forgive me if you already answered these, but have you;
1) Had the battery/alternator checked? Most places will do it for free.
2) Replaced the ignition switch? They're cheap and a 5 minute job.
3) Cleaned the inside of the headlight switch by spraying electrical contact cleaner into it?
