Originally Posted by particlewave
Don't you have a car you should be working on? Chop, chop!
Regarding your mystery tube, have you looked at the parts catalog? That may help identify it.
I actually have to work at my job during the day to afford to feed the Porsche. Went through the parts catalog. The tube is the crankcase breather tube between the PCV and the AOS. Taking off a little early today to reassemble and torque everything down. I think the DME was putting more fuel into the bank of cylinders, flooding the plugs, in an attempt to compensate for the huge vacuum leak. I'm learning and again thanks for the help!
