Old 04-04-2016, 05:44 AM   #1
nyranger6830
Looks like a new switch is north of $400
To bypass the park/neutral switch, disconnect it at the connector. Connect a jumper wire from a solid ground point to the following wires; Yellow with Violet stripe and Pink with Brown stripe. There may be 2 Yellow with Violet stripe wires or just one. If there are 2, both need to be grounded.
Do this on the harness side of the connector, not the switch side.
This will tell the car that it is in park and allow it to start IF the switch is the problem. If it does start, DO NOT attempt to put it in gear and drive as this switch also tells the car which drive gear it should be in and will cause problems.
Just jump them and try to start. If it fires, shut off and get a replacement switch.
Thanks so much, when I get home tonight Ill drag myself under my wet car and check :/ I read somewhere that the Boxster has two Neutral Saftey Switches? One activated by the push mechanism of the shifter and one obviously on the trans. Does anymone know anything about the first one mentioned?
nyranger6830 is offline   Reply With Quote
