Thread: Audio Help
Old 04-04-2016, 12:23 AM   #2
particlewave
Originally Posted by cbadbox View Post
Is there a DIY thread on that? Can I just disconnect the amp and remove it and then run wires direct to the dash and door speakers? It sounds straight forward but its something I have no experience doing.
Appreciate all the input!
You can do it that way (all new wires) or re-use the existing wires (would have to run 4 new wires to replace the common ground).
All new wires would require some hefty disassembly of dash components and door panels.
I helped someone remove the stock amp while using the existing wiring and only running 4 new wires to replace the common ground...this is easiest as most of the work is done in the frunk where the stock amp is. I'll see if I can find the thread with the instructions.
Edit: click the link, post # 5 Audio Ground Wires
