Thread: squeak sound
Old 04-03-2016, 12:20 PM   #1
PaulE
If all of you suspension bushings, motor mounts, etc are good and there are no mechanical issues causing the squeak, you may want to apply some Gummi Pflege to all of your weather stripping - frunk and trunk lids, clamshell, convertible top windshield header and doors. Gummi Plege is available from Amazon, Autogeek, and other auto detailing suppliers. Even though the Boxster was designed as a convertible an open top car is generally more flexible than a closed top car, when the unit body flexes a little over the bumps, something rubs a little bit and causes a squeak. You can also step on the gas or turn up the radio, or both!
