Thread: PSM Switch.
Old 04-03-2016, 09:49 AM   #2
The Radium King
The Radium King's Avatar
check planet 9. there is an issue w the 987 where, even when off, the psm is still present. in their case I think you can't pull the fuse/relay as that disengages abs as well? what they do is put the yaw sensor on a switch. with the yaw off then psm thinks all is good and doesn't come on. dunno about the 986 system.
Last edited by The Radium King; 04-03-2016 at 03:03 PM. Reason: http://www.planet-9.com/987-cayman-and-boxster-modifications/13861-psm-turn-off.html
