Old 04-02-2016, 04:17 PM   #21
particlewave
Originally Posted by rdymond View Post
OK will fabricate a tool and try this technique on the left (white) side. Did you have a tool for the right (black) side as well?
At this point the headlight sits on the white socket only when the white twist knob is unlocked and its keys are visible above the black mount.
First off, you're asking a question on a 6 year old post. I seriously doubt "Gent" ever checks this site anymore
Second, no need for a special tool. Remove the 2 main bulbs so you can stick your fingers through in order to pull back on the reflector and re-seat the ball and socket joints. Wear a latex glove or similar so that you don't leave fingerprints on the inside of the reflector.
Super simple and takes all of 30 seconds...I do it all the time.
