Old 04-02-2016, 08:36 AM   #15
GTA_G20
GTA_G20's Avatar
swap bulbs if its not bulbs, I'll pull my switch and you can give that a try
Its either ballast, bulbs or switch
I'd personally switch your known working parts one at a time,
Id swap bulbs from left to right. Test (the suspect bulb should bring the same issue with the passenger ballast if the bulb is bad), If the ballast is bad the known good bulb would have the same issue on the drivers side)
If same problem exist on the drivers side, Id swap ballasts from left to right, test
If same problem on drivers side the ballast and bulbs are both fine on both sides and the issue would be power to one side of the car
which I would think is a switch
2006 Audi A4 Avant 2.0t Quattro
1997 Boxster Glacier White w/facelift(gone but not forgotten)
2004 Boxster S 550 Spyder Anniversary Edition
GTA_G20 is offline   Reply With Quote
