Old 03-30-2016, 12:06 PM   #6
Cunningr
Cunningr's Avatar
First off i live in southern spain near Sevilla, weather getting perfect for top down cruising. I been living here this time round for about 9 years.
I am interested in the JBL GTO 4 inch coaxials in the dash, doors looking at the JBL GTO components. Since i am currently using the stock amp, i figure the woofer will work in the interim.
So yes currently using the stock 4 channel, i have a cheap 4 channel stock amp coming from ebay that i plan on stripping the connectors out of to build an adaptor to interface an aftermarket 6 channel amp.
Plan is to do dash speakers, door speakers, get the rear speaker kit from suncoast install that at the same time i add the aftermarket amp.
Might convert to a double din hu, the add a active ultra compact sub under the seat if ther is enough room.
Not loking for ultra high end but good soldid sound. Since i have only had the car for about 3 weeks i am still enjoying the motor sounds, but i bought the car to do some long weekend road trips, and a couple 2 weekers over to Italy, France, and Germany.
I may order some universal adapters to install the 6.5 inch in the doors i saw a write up today where someone made some home made adaptors and drilled the stock door enclosures to get some more air. This route might negate the sub.
